SS-V: 6020 Simply Supported Thin Square Plate - Transient Forced Vibration Response
Test No. VD03 View transient response of a simply supported square plate subjected to uniform forced vibration.
Definition
A simply supported thin square plate 10 x 10 x 0.05 m is subject to suddenly applied uniform pressure P=100 Pa which remains constant in time. Find peak dynamics response of the plate.
Sixteen (16) modes are used to approximate dynamics solution and 2% modal damping is assumed in all modes.
The material properties are:
Properties
Value
Modulus of Elasticity
2.e+11 Pa
Poisson's Ratio
0.3
Density
8.e+3 kg/m3
Results
The plate is simulated as a 3D solid body. Spot-lines were created at the mid-plane of the plate in order to apply hinge supports (Figure 1).
The following table contains values at peak.
Peak Time, sec Deflection Y, mm Surface Stress, MPa
0.213 -3.46 2.311 SimSolid, solid model
0.210 -3.52 2.41 Reference, thin plate model
Figure 2. Transient Response Evolution in the Plate Center
1 Test 13T from NAFEMS Publication R0016, “Selected Benchmarks for Forced Vibration” J. Maguire, D.J. Dawswell, L. Gould
